tracking and solve the slack problem when immigrate from std to pro
- 4 years ago
Hi Sstrel,
If I manually open one of the IP in the list. it will fail because "component dec_data_capture 1.0 not found or could not be instantiated".
I confirmed the file is there in the first line listed directory. I don't know why it couldn't be instantiated.
but the overall project can compile without any problem.
I just noticed most of them are from IP modules, did you re-generate the IP? Did you update them?
Nurina
Hi Nurina,
for standard version, there is a reminder to automatic or manually update the IP. for the Pro version, I didn't see any signs of over time IP or module.
I am new to platform designer, even I have gone through the training video and some part of the manual, I am still not quit confident that I did it correctly.
when you say update them, do I need to pick some of them one by one, or there is a click for all button. how do I know all the IPs are update to date?
Thank you very much for the following up post.
David
