tracking and solve the slack problem when immigrate from std to pro
- 4 years ago
Hi Sstrel,
If I manually open one of the IP in the list. it will fail because "component dec_data_capture 1.0 not found or could not be instantiated".
I confirmed the file is there in the first line listed directory. I don't know why it couldn't be instantiated.
but the overall project can compile without any problem.
Since you are using Q21.3 Pro, I'd say look at Design Assistant report and Fast Forward Compile report. These reports are useful in detecting location of the black hole and critical chain respectively.
Design Assistant: https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/ug/ug-qpp-design-recommendations.pdf#page=93
Fast forward compile: https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/ug/ug-qpp-compiler.pdf#page=30
Nurina
