11 years agotoo many instance performance degradation
I am using the Altera custom licensed version of Modelsim. It is complaining that I have too many instances (5) and there will be a performance degradation. And there is, it is unbelievab...
11 years ago --- Quote Start --- I have the performance monitor up to check on that and I have plenty of memory. 16GB and I am using 6GB. CPU usage is at about 20% I get this message when I first load the project, before it runs. I went back to the code (I am only using 16k LEs and a few multipliers, no special IP at all!) and I cut out everything I could get away with, recompiled and did NOT get the message. Modelsim ran at an acceptable speed. I then went back and did a restart and on the restart I got that message and Modelsim ran like a dog. So I quit modelsim and simply restarted modelsim from scratch, reloaded the project: NO MESSAGE! And it ran fine. Does it have something to do with restarts from within modelsim. I have noticed a lot of other bugs too. Is this just another bug?? Thanks for your help, Don --- Quote End --- Further work with modelsim shows that it still gets the error even with a small increase in project size. This is a small project, how can altera charge money for something that won't even cover the code for one of their smallest fpgas? Any help would be appreciated. Thanks, Don
