14 years agoTips for Incremental Compilation and LogicLock added to alterawiki
FYI, I added a document showing various tips for using Incremental Compilation and LogicLock to the alterawiki:
http://www.alterawiki.com/wiki/tips_for_incremental_compilation_and_logiclock Hopefully designer's find it useful.7 Replies
Hi Rysc,
this attched is missing now. could you pls re-upload it again? thank you. BR, /FC - Altera_Forum
Hi Rysc,
Thanks for the sharing. I am able to download the attachment. - Altera_Forum
Thanks for the great tips.
--- Quote Start --- FYI, I added a document showing various tips for using Incremental Compilation and LogicLock to the alterawiki: http://www.alterawiki.com/wiki/tips_for_incremental_compilation_and_logiclock Hopefully designer's find it useful. --- Quote End --- Great info sharing. Thank you. - Altera_Forum
Are there any example projects which are used to practise those tips?
Sorry, but no. Lots of these techniques are design dependent enough that it probably wouldn't be worth spending the time as opposed to trying on your own design.
--- Quote Start --- Sorry, but no. Lots of these techniques are design dependent enough that it probably wouldn't be worth spending the time as opposed to trying on your own design. --- Quote End --- Hi Rysc, Actually, this is great paper for Altera users. Thanks for you work, i hope you can share more technical papers for us!!!
