Timing simulation stuck in quartus
When I was running a timing simulation in Quartus Prime 20.1.1.720 Lite Edition, the progress is seems like to be stuck at there and not going to move anymore, below here is the last 2 sentence in the simulation log, really appreciate for any help
# MACRO ./Block1.do PAUSED at line 16
VSIM(paused)>
For the complete log:
Determining the location of the ModelSim executable...
Using: C:\Simulation\modelsim_ase\win32aloem
To specify a ModelSim executable directory, select: Tools -> Options -> EDA Tool Options
Note: if both ModelSim-Altera and ModelSim executables are available, ModelSim-Altera will be used.
**** Generating the ModelSim Testbench ****
quartus_eda --gen_testbench --tool=modelsim_oem --format=verilog --write_settings_files=off Block1 -c Block1 --vector_source="C:/Simulation/test/Waveform.vwf" --testbench_file="C:/Simulation/test/simulation/qsim/Waveform.vwf.vt"
Info: *******************************************************************
Info: Running Quartus Prime EDA Netlist Writer
Info: Version 20.1.1 Build 720 11/11/2020 SJ Lite Edition
Info: Copyright (C) 2020 Intel Corporation. All rights reserved.
Info: Your use of Intel Corporation's design tools, logic functions
Info: and other software and tools, and any partner logic
Info: functions, and any output files from any of the foregoing
Info: (including device programming or simulation files), and any
Info: associated documentation or information are expressly subject
Info: to the terms and conditions of the Intel Program License
Info: Subscription Agreement, the Intel Quartus Prime License Agreement,
Info: the Intel FPGA IP License Agreement, or other applicable license
Info: agreement, including, without limitation, that your use is for
Info: the sole purpose of programming logic devices manufactured by
Info: Intel and sold by Intel or its authorized distributors. Please
Info: refer to the applicable agreement for further details, at
Info: https://fpgasoftware.intel.com/eula.
Info: Processing started: Sat May 22 21:45:10 2021
Info: Command: quartus_eda --gen_testbench --tool=modelsim_oem --format=verilog --write_settings_files=off Block1 -c Block1 --vector_source=C:/Simulation/test/Waveform.vwf --testbench_file=C:/Simulation/test/simulation/qsim/Waveform.vwf.vt
Warning (18236): Number of processors has not been specified which may cause overloading on shared machines. Set the global assignment NUM_PARALLEL_PROCESSORS in your QSF to an appropriate value for best performance.
Completed successfully.
**** Generating the timing simulation netlist ****
quartus_eda --write_settings_files=off --simulation --functional=off --flatten_buses=off --timescale=1ps --tool=modelsim_oem --format=verilog --output_directory="C:/Simulation/test/simulation/qsim/" Block1 -c Block1
Info: Processing started: Sat May 22 21:45:11 2021
Info: Command: quartus_eda --write_settings_files=off --simulation=on --functional=off --flatten_buses=off --timescale=1ps --tool=modelsim_oem --format=verilog --output_directory=C:/Simulation/test/simulation/qsim/ Block1 -c Block1
Info (204018): Generated files "Block1.vo" and "Block1_v.sdo" in directory "C:/Simulation/test/simulation/qsim//" for EDA simulation tool
Info: Quartus Prime EDA Netlist Writer was successful. 0 errors, 1 warning
Info: Peak virtual memory: 4617 megabytes
Info: Processing ended: Sat May 22 21:45:11 2021
Info: Elapsed time: 00:00:00
Info: Total CPU time (on all processors): 00:00:01
**** Generating the ModelSim .do script ****
C:/Simulation/test/simulation/qsim/Block1.do generated.
**** Running the ModelSim simulation ****
C:/Simulation/modelsim_ase/win32aloem/vsim -c -do Block1.do
Reading C:/Simulation/modelsim_ase/tcl/vsim/pref.tcl
# 10.1d
# do Block1.do
# ** Warning: (vlib-34) Library already exists at "work".
# Model Technology ModelSim ALTERA vlog 10.1d Compiler 2012.11 Nov 2 2012
# -- Compiling module Block1
# Top level modules:
# Block1
# -- Compiling module Block1_vlg_vec_tst
# Block1_vlg_vec_tst
# vsim -L maxv_ver -L altera_ver -L altera_mf_ver -L 220model_ver -L sgate_ver -L altera_lnsim_ver -c -t 1ps -novopt work.Block1_vlg_vec_tst
# Loading work.Block1_vlg_vec_tst
# Loading maxv_ver.maxv_io
# Loading maxv_ver.maxv_lcell
# Loading maxv_ver.maxv_asynch_lcell
# Loading maxv_ver.maxv_lcell_register
# SDF 10.1d Compiler 2012.11 Nov 2 2012
# Loading instances from Block1_v.sdo
# Loading timing data from Block1_v.sdo
# ** Note: (vsim-3587) SDF Backannotation Successfully Completed.
# Time: 0 ps Iteration: 0 Instance: /Block1_vlg_vec_tst File: Waveform.vwf.vt
# after#18
# Break in Module Block1_vlg_vec_tst at Waveform.vwf.vt line 51
# Stopped at Waveform.vwf.vt line 51
# Simulation Breakpoint: Break in Module Block1_vlg_vec_tst at Waveform.vwf.vt line 51
VSIM(paused)>
- dcyh00
Issue solved when i repeat my circuit in a new project
- RichardT_altera
Hi @dcyh00
Good to know that you are able to found the solution. This will be helpful to those who may come across similar issue.
With that, I will now transition this thread to community support. If you have a new question, feel free to open a new thread to get the support from Intel experts. Otherwise, the community users will continue to help you on this thread. Thank you.
Richard Tan
