18 years ago
timing simulation spikes
--solved ...
    this can happen also in real life when decoding states to outputs asynchronously. It would be interesting, which encoding type is used for your state machine. Personally, I prefer registered output from state machines to avoid sending glitches to the outer world.
    The code has some do not do's.
    The reset should be an input, not an internal signal. Having the reset as an input is the only way you can initalize your outputs and signals to a known value.
    There are combinational loops in the second process. The reset signal is only defined in the case where state is s0. Also, when state is s7, only cycle is defined. This will cause combinational loops.
    Try rewriting the code using one synchronous process.
    example:
    process (reset, clk)
    begin
    if reset = '1' then
    cycle <= ; --put the reset value for cycle here
    state <= s0;
    outval <= ; --put the reset value for outval here
    elsif clk'event and clk = '1' then
    case state is
    when s0 =>
    state <= s1;
    cycle <= ; --insert cycle value
    outval <= ; --insert outval value
    when s1 =>
    ......and so on
    Your right, it's the asynchronous outval latch that causes the glitches. Adding outval <= '0';
    to s7 decoding removes them.
