Timing report with signal names
- 5 years ago
Short answer: no.
Longer answer: timing analysis with SDC is based on physical nodes in the design. What you're seeing is the start of a path specified as the q output of a register, part of the get_pins collection in the SDC timing netlist. When you look at a timing report in the timing analyzer, you can always cross-probe the node to other tools in Quartus, so you can see where this node is in your design.
Short answer: no.
