DeusMMJr
7 years agoTiming issues using Arria 10 Dev kit for massive design
Hi, i'm working with a huge design using Arria 10 Dev kit and i'm facing with timing issues after signoff analysis. These time issues are associated specially with DSP blocks where long combinational...
GuaBin_N_Intel
Contributor
7 years agoYes, you have to reduce the comb path if the logic level is too many. Have you registered the output of DSP block? It would help if you could pipeline those outputs to traverse much longer distance in the path( more LABs).
