Timing failure on auto assigned pins
I reported the full path timing of one of the paths for comparison, the route it takes from the FROM Node to To Node are different.
From Node: Ethernet_Bridge_inst|pll_p6_tx_to_ethernet_bridge|pll_p6_tx_inst|altera_pll_i|general[0].gpll~PLL_OUTPUT_COUNTER|divclk
To Node: P6_ind[0]
This happens when I recompile the same design for multiple times. The logic are routed differently even without any changes in the design, which is as explained in the document.
KhaiY
- SKon16 years ago
So you do see that the tool can meet timing when the pins aren't locked...and you also see that locking them (to the same location) makes the design fail timing.
Do you agree it's a bug in the P&R tool ?
Or at least something that can be considered sub-optimal behavior ?- ak6dn6 years ago
Just a question and a thought:
Do you manually set the seed value for the place/route, or let Quartus choose it each time?
Once I get a working combination, I will add to my master .qsf file:
set_global_assignment -name SEED nnnn
where I set the seed to some constant number for that layout. You can choose nnnn either before (and if you are lucky your P/R will work and meet all timing) or after a successful layout find the seed used.
Once I do this, I can rerun P/R from scratch and recreate the same layout.
- SKon16 years ago
No, I didn't change the seed manually.
I don't really understand to what value you want me to change it.
