SKon1
6 years agoTiming failure on auto assigned pins
In my design I have 3 output pins that show a timing violation in Timequest. Their location is locked by the "set_location_assignment" TCL command in the project's QSF file. Because the PC...
SKon1
6 years agoBoth designs are archived and attached.
The pins in question are:
P2_indv : AP6
P2_ind[0] : AN6
P2_ind[1] : AP8
P2_ind[2] : AL7
P2_ind[3] : AM7
According to the fitter report of both failing and non-failing designs - they're mapped to the same I/O locations.
The ONLY difference between the 2 attached designs is that the one that fails has the "set_location_assignment" constraint assigned to the above location while the one that passes doesn't have the "set_location_assignment" constraint (it's commented out from the QSF).
Thanks for your help.
SKon1
6 years agoAny news on this subject?
Have you been able to see the problem I'm describing ?
