Sajith_K_Intel
6 years agoTiming driven synthesis option is not found in Quartus 19.4 when Agilex device is selected
When using Agilex device in Quartus 19.4, There is no option to set Timing driven synthesis (in advanced synthesis settings). Hence I am not sure if SDC file will be considered during synthesis. Fro...
- 6 years ago
For Agilex, this feature had been drop
KennyT_altera
6 years agoTiming driven synthesis was enable by default in Pro. You do not need to do any thing unless you want to disable it.
https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/ug/archives/ug-qpp-compiler-18-1.pdf
page 11
As long as you put your constrain sdc files in assignemtn -> setting -> timing analyzer. it should be sufficient to let Quartus know that you had use your timing constrain.
- Sajith_K_Intel6 years ago
If so, shouldnt there be a mention about SDC in synthesis log? Bit it is not doing.
I think synthesis step then should throw syntax errors from SDC file. Somehow this is not happening.
