17 years agoTiming-Driven Synthesis is skipped...
When I run Quartus, I *always* get the message "Timing-Driven Synthesis is skipped because it could not initialize the timing netlist". This happens no matter what settings I use. Any idea what is ...
15 years agoDid you ever get this solved?
I changed a SDC file using standard Tcl constructs like if {} and foreach {} and so and got the 'dreaded' message. Turned out that A&S doesn't like the 'post_message' command, when I commented them out everything went fine again.
