17 years agoTiming-Driven Synthesis is skipped...
When I run Quartus, I *always* get the message "Timing-Driven Synthesis is skipped because it could not initialize the timing netlist". This happens no matter what settings I use. Any idea what is ...
17 years ago --- Quote Start --- When I run Quartus, I *always* get the message "Timing-Driven Synthesis is skipped because it could not initialize the timing netlist". This happens no matter what settings I use. Any idea what is going on? In case it matters, it is Quartus 9.0 SP2 on a 64-bit Vista machine. Thanks! Later that day.... Same behavior on 32-bit Vista. --- Quote End --- Hi, maybe this helps: The feature is available only for the TimeQuest Timing Analyzer and supports Arria II GX, Arria GX, Stratix series (except Stratix devices) and Cyclone series (except Cyclone devices), and HardCopy II devices. Altera recommends that you select a specific device for timing-driven synthesis to have the most accurate timing information. When auto device is selected, timing-driven synthesis uses the smallest device for the selected family to obtain timing information. Kind regards Gerd
