CWarr1
5 years agoTiming Designer Inter-Path-Competition in Nios sub-system
Timing designer is reporting 'Inter-Path-Competition' issues for my Arria-10 FPGA design. The path that is highlighted is between the Nios processor and its associated onchip memory. Since both modul...
sstrell
5 years agoCan you show the error? Timing info from the Timing Analyzer? Need more details here.
I'm not sure what the "Timing Designer" is. Do you mean the Design Assistant and you're failing a rule or something?
- CWarr15 years ago
Apologies - I meant Timing Analyzer, not Timing Designer!
I will close this request and re-post with a corrected title
