13 years agotiming constraint for clock mux and how to set output delay
Hi all, I have to constrain the output pins of my design by using "set_output_delay." The reference clock for those outputs pins comes from a clock mux. I've check the following link to kno...
11 years agoNo, you only need one of those generated clocks. It doesn't matter either, but I do the first one since it's name is independent of the global being inserted.
