11 years agoTiming constrain between pll clock and clock divisor
Hi, i have a PLL that generate three clock frequencies: 10MHz, 20MHz and 48MHz. The 20MHz clock is used to generate a 555KHz clock dividing the 20Mhz by 36. I setted up the Timing analyzer with...
11 years agoderive_pll_clocks
Then launch TimeQuest and run "Report Clocks". This will give the exact clock names for each one, and copy them to add a constraint like so: set_clock_groups -asynchronous -group {48mhz_clk} -group {10mhz_clk 20mhz_clk 555khz_clk} Naturally, your design needs to be able to handle any paths between 48MHz and the other domains as being asynchronous.
