16 years agoTiming Analyzer: Clock Skew problem
Dear all,
I am doing a project in which I need to use the audio codec of my DE2-35 development kit. I have used the i2sound demo provided in DE2 manual and modified it to take sound input (serial input from ADC) convert it to parallel and again parallel to serial for DAC (codec) then to the speaker. However when i added some processing blocks in between the serial to parallel and parallel to serial blocks the timing analyzer showed the following errors.... :(
Info: Found hold time violation between source pin or register "CLOCK_500:inst4|COUNTER_500" and destination pin or register "i2c:inst|SD_COUNTER" for clock "50MHZ" (Hold time is 1.21 ns)
Info: + Largest clock skew is 2.529 ns
Info: + Longest clock path from clock "50MHZ" to destination register is 5.219 ns
Info: 1: + IC(0.000 ns) + CELL(0.999 ns) = 0.999 ns; Loc. = PIN_N2; Fanout = 2; CLK Node = '50MHZ'
Info: 2: + IC(0.780 ns) + CELL(0.787 ns) = 2.566 ns; Loc. = LCFF_X7_Y18_N21; Fanout = 6; REG Node = 'CLOCK_500:inst4|COUNTER_500'
Info: 3: + IC(1.077 ns) + CELL(0.000 ns) = 3.643 ns; Loc. = CLKCTRL_G1; Fanout = 29; COMB Node = 'CLOCK_500:inst4|COUNTER_500~clkctrl'
Info: 4: + IC(1.039 ns) + CELL(0.537 ns) = 5.219 ns; Loc. = LCFF_X8_Y18_N19; Fanout = 14; REG Node = 'i2c:inst|SD_COUNTER'
Info: Total cell delay = 2.323 ns ( 44.51 % )
Info: Total interconnect delay = 2.896 ns ( 55.49 % )
Info: - Shortest clock path from clock "50MHZ" to source register is 2.690 ns
Info: 2: + IC(0.118 ns) + CELL(0.000 ns) = 1.117 ns; Loc. = CLKCTRL_G2; Fanout = 10; COMB Node = '50MHZ~clkctrl'
Info: 3: + IC(1.036 ns) + CELL(0.537 ns) = 2.690 ns; Loc. = LCFF_X7_Y18_N23; Fanout = 2; REG Node = 'CLOCK_500:inst4|COUNTER_500'
Info: Total cell delay = 1.536 ns ( 57.10 % )
Info: Total interconnect delay = 1.154 ns ( 42.90 % )
Info: - Micro clock to output delay of source is 0.250 ns
Info: - Shortest register to register delay is 1.335 ns
Info: 1: + IC(0.000 ns) + CELL(0.000 ns) = 0.000 ns; Loc. = LCFF_X7_Y18_N23; Fanout = 2; REG Node = 'CLOCK_500:inst4|COUNTER_500'
Info: 2: + IC(0.310 ns) + CELL(0.150 ns) = 0.460 ns; Loc. = LCCOMB_X7_Y18_N30; Fanout = 6; COMB Node = 'CLOCK_500:inst4|GO~31'
Info: 3: + IC(0.365 ns) + CELL(0.510 ns) = 1.335 ns; Loc. = LCFF_X8_Y18_N19; Fanout = 14; REG Node = 'i2c:inst|SD_COUNTER'
Info: Total cell delay = 0.660 ns ( 49.44 % )
Info: Total interconnect delay = 0.675 ns ( 50.56 % )
Info: + Micro hold delay of destination is 0.266 ns
Info: Started Full Compilation at Tue May 04 17:18:25 2010 Central Asia Standard Time
Info: Ended Full Compilation at Tue May 04 17:18:28 2010 Central Asia Standard Time
Info: Started Full Compilation at Tue May 04 17:18:50 2010 Central Asia Standard Time
Info: Ended Full Compilation at Tue May 04 17:19:38 2010 Central Asia Standard Time
can somebody explain me what is wrong and suggest me any solution! With regards omeecd
