10 years agoTiming Analysis Report
I have done a static timing analysis using TimeQuest Timing Analyzer for 100 MHz clock frequency for my design. I have got the following reports: Info (332140): No Setup paths to report I...
10 years ago --- Quote Start --- At the Compilation report, can you look at the TimeQuest Timing Analyzer tab -> Clocks, do you see your clock for your design and the assigned frequency? --- Quote End --- Yes at the Compilation report, the clcoks tab under TimeQuest Timing Analyzer tab it shows the frequency information as I set (100 MHz)
