10 years agoTiming Analysis Report
I have done a static timing analysis using TimeQuest Timing Analyzer for 100 MHz clock frequency for my design. I have got the following reports: Info (332140): No Setup paths to report I...
10 years agoDid you create a sdc file and add clock and include it into your quartus compile? Example:
create_clock -name "clkin" -period "100MHz" [ get_ports clk ] If you have set the sdc file, you should get some figures on your setup/hold. +slack means meet and -ve slack means fail timing. Also you should be able to check your Fmax as well.
