DNguy4
8 years agoTiming analysis on EMIF block
Hi, I am having a strange issue when doing timing analysis on my design. I am using the Intel external memory interface IP (emif) in my design and the timing analysis tool cannot recognize the user...
BoonT_Intel
7 years agoI will suggest you generate the example design and see if the example design have the same problem. If example design usr clk is being detected, then make comparison between your design with example design.
