DNguy4
8 years agoTiming analysis on EMIF block
Hi, I am having a strange issue when doing timing analysis on my design. I am using the Intel external memory interface IP (emif) in my design and the timing analysis tool cannot recognize the user...
DNguy4
8 years agothe attached screen shows that the emif user clock is not in the clock report. I also attache the RTL screen shot showing that user clock is connected to other device (see the red highlighted net). This case is very strange.
I can send you the design if you want.
(it looks like i can only attach one file at a time, so check the next two posts for other files)
