DNguy4
8 years agoTiming analysis on EMIF block
Hi, I am having a strange issue when doing timing analysis on my design. I am using the Intel external memory interface IP (emif) in my design and the timing analysis tool cannot recognize the user...
sstrell
8 years agoI asked because if it was not connected, it would not show up as a clock in the Name Finder, like you show in your screenshot. The signal has to drive a clock input to be recognized as a clock domain. Try using the get_pins filter just to make sure it's not connected incorrectly.
Can you run Report Clocks in the timing analyzer and see this clock there?
