8 years agoTiming Analysis: express frequency uncertainty of external oscillator
An external oscillator is connected to my FPGA. Its signal is used as a clock. There is an uncertainty of the oscillator frequency. The minimum frequency is 20 MHz and the maximum frequency is 25 MHz...
8 years ago --- Quote Start --- For your design - assuming a traditional static design consisting of registers and logic - you 'simply' need to constrain it for your faster clock. --- Quote End --- Which design would not work with this simple solution, for example? And what could I do then? Is this beyond the scope of the timing analyzer?
