8 years agoTiming Analysis: express frequency uncertainty of external oscillator
An external oscillator is connected to my FPGA. Its signal is used as a clock. There is an uncertainty of the oscillator frequency. The minimum frequency is 20 MHz and the maximum frequency is 25 MHz...
8 years ago --- Quote Start --- That's not what the set_clock_uncertainty is for. --- Quote End --- I already suspected it. --- Quote Start --- Providing it runs at 25MHz it'll run quite happily at 20MHz. You may need to be careful if you use PLLs or other timing related IP. --- Quote End --- Thanks a lot!
