BISIK
7 years agoTiming analysis after analysis&synthesis step in Quartus 14.
I want to find maximum frequency(or slack time) of an arithmetic operation in Quartus14. But Timequest analyzer, give a Run Fitter before Timequest error, when creating nets. Is there a way without c...
- 7 years ago
You can create a post-map timing netlist (you have to choose it manually from the Netlist menu in the timing analyzer) and perform an analysis on that, but it won't represent final timing in the design.
sstrell
7 years agoYou can create a post-map timing netlist (you have to choose it manually from the Netlist menu in the timing analyzer) and perform an analysis on that, but it won't represent final timing in the design.
