14 years agoTimequest: toggle synchronizer constraints?
Hi Ryan (Rysc) and anyone else with suggestions, I have a TimeQuest question I was hoping you might be able to answer. I have a toggle synchronizer that is used internal to a design. The t...
14 years agoThe paths in that screenshot are for register objects.
If instead of the register, you want one of those register's clock pin, then you just add |clk to the path I think adding a clock on the pin will suppress the warning.
