12 years agoRun in TimeQuest:
report_timing -setup -npaths 20 -detail full_path -panel_name "setup" -file "./TQ/TQ_20setup_paths.txt" You can add -from/-to options to specify the I/O, but if they're the worst case they come up by default. Then attach the .txt file to this. From pin to pin, your pinout makes a big difference. You might want to try manually assigning them close to each other. (I haven't found the fitter to be that good at pin assignments).
