13 years agoTimeQuest Timing Analyzer[Setup slack analysis]
HI, I am trying to understand how the Time Quest analyzer calculating required setup and hold time.I have written code for register and the clocks are common(50 MHz). As per my understanding da...
10 years agoThe waveform is good for getting your bearings, but the Data Arrival tab has all the details. External delays should show up as iExt or oExt as the delay type in that report, so you can directly see how it's used in the calculation.
