12 years ago
Timequest Timescale
Are timequest timing constraints always in nanseconds? I have trawled through the documents, the help system, the forum and via Gxxgle, finding nothing. If I put "5ns" in an SDC is the ns ignored?
Cheers,
    --- Quote Start ---
    Cheers,
    --- Quote End ---
    excerpt from altera doc:
    "Enter time values in default time units of nanoseconds (ns) with up to three decimal
    places. Note that the TimeQuest analyzer does not display the default time unit when
    it displays time values.
    You can specify a different default time unit with the set_time_format -unit <default
    time unit> command, or specify another unit when you enter a time value, for
    example, 300ps."
    You can also define frequency of clocks as -period "<val> MHz" but this is not standard sdc but unique to TQ
    Thanks, Kaz, that's exactly what I wanted to know. Where did you find it?
    Simon
    --- Quote Start ---
    Simon
    --- Quote End ---
    not easy to find.
    qts_qii53019.pdf
    topic: switching to quartus timequest timing analyser
    timing units, page 8-6
    Ah, now I know what to look for, it is also in the SDC and TimeQuest API Reference Manual, although not in the November 2008 version which I printed out long ago.
    As an observation, there are a huge number of documents explaining SDC constraints, for an end result of a few sentances of commands at least for the average FPGA. I can't help feeling that the concept is flawed if it is so difficult to use.
    Simon
