IDeyn
Contributor
7 years agoTimeQuest strange behavior - seems like a bug in PLL output clock visualization
Hi all! Recently faced such problem - in the test project there are two PLLs, with input from two base input clocks. One clock is 50 MHz with waveform { 0.000 10.000 } and on also 50 MHz with wavef...
Abe
7 years agoI guess, when you're shifting the clocks manually without using the PLLs phase shift feature, then you would have to generate the output clocks manually using the create_generated_clocks constraints. The derive_pll_clocks works well when the PLL is used for phase shifting the clocks. It generates the required clocks with respect to the PLL configuration settings.
