IDeyn
Contributor
7 years agoTimeQuest strange behavior - seems like a bug in PLL output clock visualization
Hi all! Recently faced such problem - in the test project there are two PLLs, with input from two base input clocks. One clock is 50 MHz with waveform { 0.000 10.000 } and on also 50 MHz with wavef...
KhaiChein_Y_Intel
7 years agoHi Ivan,
Can you use the PLL to perform shifting?
