10 years agoTimequest: Source synchronous timing isn't moving when I adjust PLL
I have a bit of a confusing timing issue. I have a source synchronous DDR LVDS output interface in which the data and clock are centre aligned. This all passes timing and I am happy with all the ...
10 years agoIf you use the "create_ generated_clock" command in your SDC, yes; You should modify your constraints in order to reflect phase shift.
If you have used the "derive_pll_clocks" in the SDC file, no; It is automatically translated into appropriate commands.
