My project is based on a cyclone II anche the filter is narrowband band pass with 16 input ant 60 taps. I had warning n the same place using quartus v 9 and the classic timing analyzer, so I suppose the clock settings are right.
The clock is divided using the clock enable approach so reading the documentation of timeqest the multicycle semms to be the right way...
Anyway there are more than 100 setup warning so my question rised to understand if there is a faster way to introduce multicycle settings bacause the project is in the eary stage and I am not sure the fulter I ma usung will be the definitive one.
Kaz I suppose all the registers in the filter are fed by the clock enable but the multicycle setting can be applied only to path or I am wrong?
