16 years agoThe piece named clock pessimism is named poorly in the timing report. It is actually reporting the pessimism that was removed. So, this item would be 0 of removal was disabled (might not even be listed in the timing report). I would expect the "clock pessimism" line in the timing report to be non-zero when the pessimism removal is enabled.
