15 years agoI read your full document. The register in my case is part of my reset sync IP that is stamped out many times throughout the design. While the "(* dont_merge *)" directive seems attractive, it will cause pretty much all of my resets in the design not to be optimized - which would probably be overkill and would ignore registers that can safely be combined.
What I will do later is disable the merge in Assignment Editor for that register only and see what happens. I am kind of not too comfortable with Quartus making that false analysis, but would like to make sure that I don't actually have an issue that is mis-reported. Too bad this is a big project and can't safely be shared - I would otherwise send it to Altera Support to see what they think.
