15 years agoRysc,
You were correct (of course) - by disabling the removal of duplicate registers, all of the timing violations make sense now. That being the case, my assumption is that the weird violations I was seeing with that option enabled, are truly false and can be safely ignored. If the register that was combined (and is now hidden) caused a violation, that would then show up as a valid violated path. Is that a safe assumption? Thank you!
