9 years agoTimeQuest found "Unconstrained Paths"
Hello, Before approach "timing analysis" I've studied the ryan scoville's "TimeQuest User Guide", that can be found here: http://alterawiki.com/wiki/timequest_user_guide In the sectio...
9 years ago --- Quote Start --- Hi, create generated clock for clock output pin which goes to SDRAM chip and constrain output pins to clk_ext
create_generated_clock -name clk_ext -source
set_false_path -to Create virtual clock and constrain input ports to virtual clock clk_ext_virt create_clock -name clk_ext_virt -period --- Quote End --- Hi, Thanks for suggestion ... but "generated clock" is already created by the command derive_pll_clocks. There are 2 such clocks (with same frequency) that output from the PLL. One of them clocks all components in Qsys (including CPU NIOS II), whereas other goes out and clocks sdram. The clock that goes to sdram I pick from the timequest clock analysis and put it into .SDC using following instruction: set clk_ext [get_nets u0|pll|altera_pll_i|general[1].gpll~PLL_OUTPUT_COUNTER|divclk] Then I use it as clock source in set_input_delay and set_output_delay. As I understood (perhaps incorrectly) when the command derive_pll_clocks is used, it fixes all PLL-generated clocks, isn't it ? Concerning virtual clock, in all documents that I saw before, virtual clock is used only if clock is generated out of FPGA, whereas in my case clock is generated inside FPGA. Again, perhaps my perception isn't correct ?
