14 years agoSince you're feeding DCO back to the FPGA and using it to latch_data, you need to have it as a non-virtual clock.
Since all those clocks are related, I think it's best to analyze them as such. Here's how I'd go about it -- for 1 ADC. A bit of Verilog to illustrate module an_example (sysclk, sclk, dco, d, q); input wire sysclk; output wire sclk; input wire dco; input wire d; output wire q; wire adcclk; pll0(.inclk0(sysclk), .c0(adcclk)); assign sclk = adcclk; reg d_r; always @ (posedge dco) d_r <= d; reg q_r; always @ (posedge adcclk) q_r <= d_r; assign q = q_r; endmodule And the .sdc # Base clock create_clock -name sysclk -period 20 [get_ports sysclk] # PLL clocks derive_pll_clocks set adcclk {comb_3|altpll_component|auto_generated|pll1|clk[0]} # # Example for 1 AD7626 # SCLK to ADC create_generated_clock -source $adcclk -name sclk [get_ports sclk] # Tricky part: DCO from the ADC # It is derived from the SCLK but has a 0-7 ns delay # (or a bit more if you account for wire delay)# First, create a derived clock with 0 ns delay create_generated_clock -source sclk -name dco [get_ports dco]# Then use clock uncertainty to represent the 0-7 possible delay set_clock_uncertainty -from dco -to $adcclk -setup 7.0 # Now we can add I/O delays, referenced to the proper clocks set_output_delay -clock sclk -min ??? [get_ports cnv] set_output_delay -clock sclk -max ??? [get_ports cnv] set_input_delay -clock dco -min 0.0 [get_ports d] set_input_delay -clock dco -max 1.0 [get_ports d] # This will calculate the skews and uncertainties for the clocks within the FPGA # the -add is important, otherwise TQ will ignore the uncertainty assignment above and will treat dco as an exact replica of sclk derive_clock_uncertainty -add
