11 years agoTimequest: -clock is not an object ID
In my sdc file I have a set_input delay command as set_input_delay -add_delay -clock { dctu_i|a_uniphy_i|a_uniphy_inst|pll0|pll_afi_clk } -min -0.01 [get_ports { my_signal}] I keep getti...
11 years agoRysc,
Thanks for your reply. It is the latter that is the problem. My .sdc script order had magically changed around in the quartus settings. As I use the read sdc macro command from the left hand side of the timequest quest GUI, I think it uses the order in the Quartus settings. Problem solved now. Thanks Rysc C
