10 years ago[TimeQuest] -> How to generate the Timing Summary Report?
Hi Al
How can I generate the Timing Summary Report in the TimeQuest (see the image below)? http://www.alteraforum.com/forum/attachment.php?attachmentid=11796&stc=1 Thank you!3 Replies
in TimeQuest, go "Reports" -> "Custom Reports" -> "Report Timing...". Select an analysis (e.g. "Setup") and a number of paths (only the n worst-case paths will be reported). In "Detail Level", select "Summary" for the first window in your screenshot, or "Full Path" for the 3rd one. I have no clue what the 2nd window, the one with the blue bars, is, though. Best regards, GooGooCluster - Altera_Forum
2nd windows is slack times histogram
What's the difference between the "Path Only", "Path and Clock" and "Full Path"? Where can I read about these types of reports? Thank you!
