10 years agoTimequest - Constrating Centre-Aligned SDR
No matter how many times I try and read through the various documents on timing constraints, I can never quite fathom how to apply it to my design. For example, I have the following which I wan...
10 years agoI'm using DDIO blocks to try and minimise any skew between the clock and data - feeding the clock and data out directly would result in big differences as the clock is on the global network and the data has to travel a fair way through the chip to it's IO pin. I basically for the clock have it drive a 0 on the rising edge (so connected to the H input) and 1 on the falling edge (L input). For the data both the H and L inputs of the DDIO block are connected together - essentially forming an SDR interface. I used to use Xilinx FPGAs and this was apparently the optimal way of doing it on those, so I'm applying the same principal here.
I had initially tried with settings of I think about -max of 3 and -min of -3 based on the various examples (and calculating with the figures I have for delays and whatnot). But this failed timing with hold violations of pretty much any number I put in the -min constraint, which is why I was getting very confused. There were no setup violations, just hold. I was trying to get timequest to spit out information on why the path was failing using the "Report Timing..." option, but I couldn't seem to get it to tell me anything - it kept saying no paths found to each of the searches I tried.
