13 years agotime_limited.sof file with subscription edition
Hi
We purchased quartus II License recently. When I am compiling any code with NIOS Processor and some interfaces The output programming file is xyz_time_limited.sof instead of xyz.sof ? Why it is time limited ? what does that means .. will it last for some limited time.. not for production use... I am using quartus ii 12.0 subsciption edition. Before downloading the license file, i used this tool in trial version (no compilation was completed). But today after license file download, it is giving this output. I don't know these things are related or not. Although in web edition the same project was giving right output xyz.sof. I am getting the warning from compiler - --Warning (12190): "Nios II Processor (6AF7_00A2)" will use the OpenCore Plus Hardware Evaluation feature ---Warning (12190): "Nios II Processor (6AF7_00A2)" will use the OpenCore Plus Hardware Evaluation feature ---Warning (265069): Megafunction that supports OpenCore Plus feature will stop functioning in 1 hour after device is programmed Please suggest.
