I managed to implement a program which checks the rows of the array, now for the columns...
I want to implement An array of FSM situations, so that for each column that I'm checking presently they will be a memory
of the last row same column to compare to. that's because the information of the X/0 table is given by the input of the
user (testbench) and I don't want to save all of it.
( if the board is n*n and n=999999 .....)
so I wrote as follows:
type C_state_type is (IDLE_C, X_chk_C, O_chk_C, tmp_draw_C);
signal cur_st_C, nxt_st_C is array (1 to n) of C_state_type;
any idea if this can be implemented somehow? If so, what should I
change? because modelsim doesn't agree to this.
Thanks, Amitai
