This is the command generated while I am installing the Altera complete design suite free package -v11.1 for windows. how to solve it.
nstaller subprocess for Quartus II Web Edition (Free) exited abnormally.
status code = 5
command = "C:\\Users\\NITM\\AppData\\Local\\Temp\\11.1_173_quartus_free_windows\\altera_installer\\bin\\..\\..\\windows_installer\\quartus_free\\quartus_free_windows_nsis.exe" /SHOW_PROGRESS /S /PROGRAM_FILES=Altera 11.1 Build 173 (Copy 9) /D=c:\altera\11.1
- CalvinJoaz_P_Intel
Contributor
Hi Hari,
I can't access the link you provided, as it's seems like specified device path file.
Can you provide printscreen of the generated command?
Kindly check 'Intel® FPGA Software Installation and Licensing' link below too.
https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/manual/quartus_install.pdf
Thank you.
- Philipp
Hi Calvin,
I encountered the same issue while trying to install Quartus II Web Edition v11.1 Service Pack 2. The installer gives following error message:
Installer subprocess for Quartus II Web Edition (Free) exited abnormally.
status code = 5
command = "D:\\Altera_tmp\\11.1sp2_259_quartus_free_windows\\altera_installer\\bin\\..\\..\\windows_installer\\quartus_free\\quartus_free_windows_nsis.exe" /SHOW_PROGRESS /S /PROGRAM_FILES=Altera 11.1sp2 Build 259 /D=c:\altera\11.1sp2
(I also attached a screenshot of the installer)
The same applies to Quartus II Programmer Software v11.1 Service Pack 2.
I couldn't find any documentation about the status code. Can you please provide information what that means and/or why the installation fails?
Many thanks in advance!
With best regards
Philipp Weisbach
- sstrell
Older free versions of the software required the Talkback feature to be enabled, which no longer exists. That could be the problem. Any reason why you can't use a more recent version?
