8 years agoThe result is right in emulator mode, but is wrong in FPGA
My code result is right in emulator mode, but when I compiled it and run in FPGA, the result is wrong. What reasons will cause the problem? And how to debug code in the situation? The code need...
8 years ago --- Quote Start --- I have not explored this design pattern yet; but is this due to a lack of cache coherence (in the LSUs that are automatically inferred)? Did you ever bring this up with Altera or get a response? --- Quote End --- This is not a bug, this is part of the OpenCL specification. Global memory consistency is only guaranteed at the end of kernel execution and hence, one should not expect consistency when kernels running in parallel are reading from/writing to the same global address. Channels are meant to be used for passing data between kernels, not synchronizing global memory load/stores.
