15 years agoHi Davlka
In the process of learning SDR Source-Synchronous Output,I found that the output delay max and the output delay min are hard to be understand.you can see that the output delay min occurs before the latch edge and the output delay max occurs after the latch edge.So I think the output delay max shoud be Th and the output delay min should be -Tsu. Could you give some suggestion? thank you very much!
