Sam_Chang
5 years agoThe problem about Transceiver Toolkit for testing IP : altera_xcvr_10gkr_a10
Hi all,
I want to test BER in Transceiver Toolkit for altera_xcvr_10gkr_a10,
In IP Parameter, I choose "Enable Hard PRBS and Native PHY Debug Master Endpoint support"
After compile, in Transce...
- 5 years ago
Hi
If you can use the Native PHY IP will be a great help to narrow down the problem, you may use the 10G base R preset setting in Native PHY IP and then enable the PHY to debug the master port. This can help to rule out if there is any dependency on the BASR KR IP or any design connection relate problem.
Regards -SK
SengKok_L_Intel
5 years agoHi,
Before using the TTK, does this design working fine with any other traffic test? You might need to double-check your design if there is any clock/reset connection concern.
Regards -SK
- Sam_Chang5 years ago
I double-check the clock/reset connection is connected
the problem is still not solved
