agaripcan6223
8 years agoThe operating frequency of Floating Point ip-cores
Hi to everybody. Can you help me about a subject. I am working on hardware modeling of the chaotic Sinus map. The equation of the sinus map is as follows. For modeling, I use ip-cores defined on IEEE...
agaripcan6223
8 years agoI will use random signals from the chaotic circuit for sampling purposes. If the sampling frequency is high, the system will make sampling so fast. In short, I aim to increase the output bit rate of the system. You can check the figure 4.
