agaripcan6223
8 years agoThe operating frequency of Floating Point ip-cores
Hi to everybody. Can you help me about a subject. I am working on hardware modeling of the chaotic Sinus map. The equation of the sinus map is as follows. For modeling, I use ip-cores defined on IEEE...
Tricky
8 years agoDid you even look at the timing report? 1GHz is NOT going to be possible inside an FPGA. For a cyclone, you'll be doing good if you get >200 MHz
