NLewi3
7 years agoThe NIC ID for my Quartus Prime Pro License does not match the NIC Card in my machine. Should these two NIC IDs match? Because the License generated by the Self Licensing Center does not permit Quartus to execute.
AR_A_Intel
7 years agoHello
Welcome to INTEL forum. Could provide again your license .dat file and your machine NICID for checking? And you can also reply/attach your file in private message.
- NLewi37 years ago
Attached is the License.dat file generated by the Self Licensing Center and here is the result of an ‘ipconfig /all’ command: C:\Users\admin>ipconfig /all Windows IP Configuration Host Name . . . . . . . . . . . . : NLEWISW10CORP Primary Dns Suffix . . . . . . . : Node Type . . . . . . . . . . . . : Hybrid IP Routing Enabled. . . . . . . . : No WINS Proxy Enabled. . . . . . . . : No Ethernet adapter Ethernet: Connection-specific DNS Suffix . : Description . . . . . . . . . . . : Intel(R) Ethernet Connection (2) I219-LM Physical Address. . . . . . . . . : 18-66-DA-1F-FB-72 DHCP Enabled. . . . . . . . . . . : Yes Autoconfiguration Enabled . . . . : Yes Link-local IPv6 Address . . . . . : fe80::e048:809a:e77c:ef64%14(Preferred) IPv4 Address. . . . . . . . . . . : 10.0.1.179(Preferred) Subnet Mask . . . . . . . . . . . : 255.255.255.0 Lease Obtained. . . . . . . . . . : Wednesday, May 29, 2019 8:13:02 AM Lease Expires . . . . . . . . . . : Thursday, May 30, 2019 8:13:02 AM Default Gateway . . . . . . . . . : 10.0.1.1 DHCP Server . . . . . . . . . . . : 10.0.1.1 DHCPv6 IAID . . . . . . . . . . . : 353920730 DHCPv6 Client DUID. . . . . . . . : 00-01-00-01-1F-1E-D7-6B-18-66-DA-1F-FB-72 DNS Servers . . . . . . . . . . . : 68.94.156.1 68.94.157.1 NetBIOS over Tcpip. . . . . . . . : Enabled
